Se la denomina Site to Site teniendo la posibilidad de acceder a recursos de una compañía que se encuentren en una locación remota.
GoodCloud cloud management service provide an easy and simple way to remotely access and manage routers. Beside we have configured
Site to Site to allow offices in multiple locations to establish secure connections with each other over internet.
LABORATORIO DE PRUEBA
COMANDOS UTILIZADOS
https://forum.openwrt.org/t/ookla-speedtest-cli/66345/25
wget https://install.speedtest.net/app/cli/ookla-speedtest-1.1.1-linux-aarch64.tgz
tar zxvf ookla-speedtest-1.1.1-linux-aarch64.tgz
ls -l
ll
./speedtest
Cliente Medido de forma bidireccional
Windows
iperf3.exe -c 192.168.8.183 -R -t 15 | Vemos el download
iperf3.exe -c 192.168.8.183 -t 15 | Vemos el upload
iperf3.exe -c 192.168.9.183 -R -t 15 --get-server-output
Server
Linux
iperf3 -s
Como configurar gl.inet routers, como configurar goodcloud, how to config goodcloud, how to config gl.inet,
como configurar un site to site, acceder a redes remotas con opwnert, how to access to remote network via gl.inet,
monitoreo de equipos de forma remota, how to monitor routers in a remote way, manage remote routers,Install a Router as ZeroTier Client ,Instalar un Router como Cliente ZeroTier,connect whole home network router through home,Route between ZeroTier and Physical Networks,Bridge your ZeroTier and local network with a RaspberryPi,Lan to Lan via ZeroTier,home assistant zerotier addon,instalar home assistant en raspberry pi,Redes remotas,Configuración de router,Conexión remota,Red privada virtual,Zerotier on routers,Port Forwarding on router,Server ZeroTier,Client ZeroTier,ZeroTier Access lan,Zerotier over LTE,Remote access web Admin Panel,Remote access router's terminal,Firewall,Navegar en Internet usando Zerotier,Configuration,Check live router status,Monitoring clients on routers remotely,Virtual Office,extend your office network to other offices,Smart Home,remote access IP camera, NAS and other devices at home,Acceder a Camaras IP de Forma remota,Remote access web Admin Panel,Wi-Fi Management System,Set up routers remotely,relay server,Tunel,IpSec,Tunneling,PPTP VPN Server,VPN authentication,Virtual Private Network,system administrator,proxy,security,privacity,privacy,seguridad,privacidad,Creación de la red y configuración inicial,Instalar y configurar Zerotier,Accede a tu red desde cualquier lugar,CGNAT,Redirecionamiento de Puertos,Tutorial,How to access home network from internet,Cómo conectarse fuera de casa desde una red exterior,capacitacion,educacion,gli-net,Wireguard,OpenVPN,glinet,gl.net,gl-inet,Beryl AX,VPN connection,TailScale,WPA3 protocol,Brume 2,Configuración ZeroTier en Routers GL.iNET con OpenWrt,SD-WAN,Tor Anonymity,AdGuard Home,Fast and Secure Browsing,Flint 2,GL-MT6000 Wi-Fi 6 AX6000 Home Router,GL-MT3000 Wi-Fi 6 Travel Router,Security Gateway for Remote Access,OSI Model Modelo,GL-MT2500 / GL-MT2500A,hosting VPN server,VPN Cascading,VPN Gateway for Home Office and Remote Work,TCP/IP,Testing,Seguridad en Internet ,MikroTik,Modo Bridge o puente,Router NAT,Red Privada,Red Publica,IP Address,devices in a home network without having to install VPN software on each device.,NordVPN,ExpressVPN,PIA (Private Internet Access),PrivateVPN,Proton VPN,PureVPN,Surfshark,TorGuard,AirVPN,Astrill,BolehVPN,CactusVPN,Cryptostorm,CyberGhost,FastestVPN,FinchVPN,HideIPVPN,Hide.me VPN,HideMyAss,IPVANISH,IVACY,IVPN,OVPN,PrivadoVPN,SaferVPN,StarVPN,StreamVPN,StrongVPN,VPN.AC,VPNGate,VPN Unlimited(KeepSolid),VyprVPN,ZoogVPN,AzireVPN,Mullvad,ANONINE,AirVPN,Astrill,Hide.me VPN,IVPN,NVPN,OVPN,PIA (Private Internet Access),PrivateVPN,Proton VPN,PureVPN,SpiderVPN,StarVPN,StrongVPN,Surfshark,TorGuard,TRUST.ZONE,VPN.AC,VPN Unlimited(KeepSolid),Windscribe,12VPX,Why use a VPN?,Why use a VPN Router?,Spitz AX,GL-X3000 Wi-Fi 6 Cellular Gateway,Wi-Fi 6 Dual-SIM 4G/5G Cellular Gateway,Site to Site connection,overlay networking for the Internet of Things,Industrial IoT,RMM ,Embedded Networking,Enable GoodCloud on router
